In-Stream Modifiers for Dimensions
Create the dimension menu that allows the user to input or select the options they need for the dimensions they are about to insert.
Items such as pre-fixed text, Post text, tolerances, Geometric Tolerances, precisions, etc.
These settings would stay active for all following dimensions and allow the user to modify such on the fly for the next few dimensions as required until completed.
In essence, if I have 5 dimensions that require the pre-text of "2X" and a 3 place decimal and 8 dimensions that have no text but a 2 place decimal, I select the settings, insert those 5 dimensions and then make the needed changes for any following dimensions and this continues all without having to exit the dimension command.
CADDS5 had this ability back in the late 80's and honestly anything that reduces the time I have to spend detailing a part, the better.
4 Comments
Unfortunately this is the best picture example I could find of the old CADDS5 menu.
It's not exact, but it might get the idea across. I will keep looking for a picture of the actual CADDS5 dimension menu I'm talking about.
Curtis_Waguespack
I think this image illustrates something similar as far as the predefined text and tolerances, from AutoCAD Mechanical:
image courtesy of http://www.mastergraphics.com
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
