Sweep - Add Twist Option
Add the ability to control twist (angle value in sweep dialog,rather than drawing explicit rail) while sweeping a profile. This can already be done within AutoCAD which shares the same Shape Manager kernel as Inventor so technically it just needs exposing to Inventor
8 Comments
al_inventor
Sweeping operations command, the guide rails and guide surface, a greater number of options, guide rails and guide surface, the addition of the option of using. In addition, during the process of sweeping the option to be added twist. These improvements will bring ease of modeling processes.
pompeo79
Ability to give a torsion to a sweep feature (as present in Autocad), with angle or number or loop.
Please! That feature is very important¡
dan_szymanski
This project [US15011] is under review by the development team.
dan_szymanski
Status changed to: Gathering Support
This idea has already been submitted (here). Please refrain from casting kudos to this Duplicate listing as it splits the potential votes between two items. Thanks.
Likewise this project [US15011] is under review by the development team.
Dan
dan_szymanski
dan_szymanski
Status changed to: Accepted
Accepted idea [US15011]. Thanks!
dan_szymanski
This idea has been implemented within Autodesk Inventor 2015. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it. Enhancements have been made within the Part Modeling environment, so that when creating a sweep, you can now enter a twist angle to control the rotations of the profile perpendicular to the path. The twist angle you specify determines how much the profile twists along the given path. Please be sure to check this out in Autodesk Inventor 2015. Thanks!
