Improved patch command.
Patch command, in order to make more complex patches can be improved.
Patching process only;
1 - patched where you can select the edge lines,
2 - Weight Factors adjust,
options open is not enough.
The patch process, the patch can commit to use the options in the guide lines of the road, should be added to the command options.
1 Comment
dan_szymanski
This idea has been implemented within Autodesk Inventor 2017. Guide rails can now be specified during the creation of a boundary patch. Special thanks to everyone who cast a vote for it.
