The UCS command inside the Assembly environment is not as useful as in the Part environment. In the part environment we can set up a ucs with three points. In the assembly environment it is not so easy. We make tubes swept along a centerline. We need to take measurements from points where the centerlines intersect from an assembly context. We have work arounds, but making the UCS command work the same in both environments would make life simpler.
