Improve Joint Icons - Protect Status
Currently when a Joint command is Locked in Inventor 2014, it is very easy to tell in the browser that the degree of freedom has been removed due to the locking procedure.  The Show Relationships button also designates a Lock.
On the flip side a Protect of a Degree of Freedom is not clearly stated in the browser to a user.  The only way to tell that a DOF is protected is to RMB on it in the browser and inspect the status.  The Show Relationship button does not show a Protect status.
Here is the problem, if a user Protects a degree of freedom the next relationship that tries to remove the protected DOF will spring a generic error message about a failed relationship.  Without knowledge of the Protected DOF, the user would start deleting Relationships in order to get the design to work or to adjust it.  This would be either the originating user that created the design or another user picking up someone else's assembly and trying to work with it and running into frustration.
Solution: Icon references for Protect Status or more robust error triggering on a Protected DOF.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
