Currently, 2013, iLogic Events are stored in the local file. I would like to have Global Event Triggers that would be configured in the Application Options. For example:
- Set a Global Event Trigger on all IPT and IAM when used as a New Document
- Global Trigger would run an External Rule that opens a Global Form for iProperties
This would work for all templates without having to edit the templates. OR...
- Global Event before or after Save
- Fires an External Rule to check for required iProperties.
- If they are not filled out then a Global Form is launched.
If we had Global EventsThis would work on ALL data that was created before iLogic.
