35 Kudos
Frame Generator Enhancements
Status: Accepted
by Valued Contributor EScales on ‎11-30-2012 12:47 PM
1. How about adding in some plate joints when mitering.
2. It would be nice to have bar grating as an option in Content Center and when using the Frame Generator.
3. An quick way of creating industrial stairs, for platforms and catwalks, made from bar grating stair treads with the nosing already on them.
4. Maybe an automated handrail command.  It could automatically build the top rail, mid rails and toe kicks per the ANSI standards for platforms and stairways.
In general, there needs to be a lot more structural steel component automation.  If it can be done in AutoCAD, why not Inventor?  Companys that design complete equipment with steel structures could benefit from this.
Status: Accepted
Accepted idea [US14241]. Thanks!
Comments
by maartenverbunt on ‎01-04-2013 06:21 AM
Yes, I would love to have more usable components as well, like coupling plates and end caps/plates.
by Distinguished Contributor cadman777 ‎01-07-2013 08:18 AM - edited ‎01-07-2013 08:19 AM
Frame generator's biggest weakness is it doesn't allow use of metadata (= exported parameters) in the editing tools. Also, you can't use frame generator part parameters anywhere for fear if you change your design, they will disappear, and due to "cyclical dependency" if imported into the base part (for those who use base parts to build equipment and weldments).
We're not asking for StruCAD, but for something  more "robust" that we can do small structural work and INTEGRATE the frame generator into the rest of the basic modeling process. The use of metadata is the key here.
... Chris
by Employee BryanKelley on ‎01-28-2013 02:51 PM
This project [US14241] is under review by the development team.
by Employee dan.szymanski on ‎03-14-2013 08:25 AM
Status changed to: Accepted
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea.
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
