HSM simulation display quality improvement
When simulating toolpaths in HSM Express it comes to my attention that the display quality of the stock-material is poor (see picture). In my opinion this should be improved, because we're unable to evaluate the milling process properly.Poor quality of simulation of stock material
4 Comments
I need more tolerance to export files 0.01mm is not enough.
BryanKelley
Hello Designboltz,
  Some clarification.  Within Frame Generator you need a tighter tolerance, down to 0.01mm when you export files?  Can you walk me through the workflow that you are doing?
Thank you,
Bryan
dan_szymanski
Status changed to: Accepted
Accepted idea [US7701]. Thanks!
dan_szymanski
This idea has been implemented within Autodesk Inventor 2014.
