Fix the 2013 Text Box
Since upgrading to 2013 we have had an issue of the text box removing dimension lines. This need to be fixed!
If Autodesk is going to supply a white out feature like AutoCAD has then it need to do the following:
1. Remove all geometry behind the text box not just the dimension lines.
2. Have a switch to control weather you can see what is behind the text box or note. (Most cases I want to see through the text box)
3. Text box should automatically resize based on what text is in it.
I have been told this new text box issue is a new feature in Inventor. I sure wish it where a useful feature and not just another hope for use trained animals to have to jump through.
Cheers
Mike
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
