Radius dimension with Jog include center mark and jogged linear dimensions
 I would like the ability to add a center mark and dimension linear dimensions to jogged (or Forshortened) radius in drawing.  Currently the Jogged radius does not jog the center mark and linear dimensions.
29 Comments
I would like to be able to place the dimension, then drag the extension line to an appropriate position per this thread:
http://forums.autodesk.com/t5/Autodesk-Inventor/Dimension-Extention-Line-Jog/td-p/3432139
Useful for example when dimensioning multiple bores that are similar in size, extension lines can be too close together without this functionality.
SBix26
This could work by right click on the appropriate extension line and choose Add Jog, which could then be manipulated like an Ordinate dimension line.  Right click again to select Remove Jog.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
BryanKelley
Hello Andrew,
  Is the dimension shown in the previous post on the other forum an ordinate dimension?  Can you post the drawing file and the part it is documenting here?
  I'm not aware that there are any standards that recognize a jogged extension line for linear dimensions.
Bryan
Sr. Software QA Engineer
DLS – Mechanical Design
BryanKelley
Status changed to: Comments Requested
LT.Rusty
I don't know about jogging linear dimensions, but I'd love to be able to jog radial dimensions and hole notes, etc., in the same way that you can add a vertex to leader text.  There's times when that would be VERY handy.
I'm not aware of any standards either. Regardless, I would still like the option added to ensure that my drawings can be illustrated much more clearly where I see fit.
I was able to do this in pro\engineer 13 years ago.
whether in a standard or not, I think this needs to be an option, as it is extreamily useful when designing miniature components with fine detail.
dan_szymanski
Junko.Nanga
The jog direction for the radius dimension of Inventor has consistency which means no change jog direction even if move the dimension to anywhere as the following movie.
http://autode.sk/1M41eFk
However for ACM, it would be changed accordingly as the following.
http://autode.sk/1LAyePU
I would like Inventor's dimension to be same behavior as ACM's one.
Thanks.
dan_szymanski
Status changed to: Gathering Support
jamie.white
This has been an issue for far too long!  I have seen posts from '01 with the same request.  This post is from '13.  It is now '16 and it still isn't resolved.  Please add the feature to all linear dimension lines to be jogged so we don't have to fake the dimension anymore!  Thanks.
burtploof9085
SolidWorks has had this option since 2008, standard or not.
Currently switching to PTC software as it's now cheaper and doesn't have any of these usability niggles. About time Autodesk fixed these basic niggles instead of concentrating on expanding capability with bolt-ons that I will never use.
This feature exists in other Solid modeling packages and would be great add.
jeffsteiger6735
16 plus years of user requests and then it's just "Archived".
Good work Autodesk.....
dan_szymanski
Hello @jeffsteiger6735
Sorry for the confusion here.  I suspect while reviewing Ideas, an admin merged a duplicate Idea post into this Master Idea.  In doing so the votes get transferred & credited into the Master Idea, however the comments also come along in the merge.  I suspect the duplicate post possessed minimal support and was archived, thus the "archive messaging" comment came along for the ride.
The "16 years" comment is a more complicated issue (in nature) tied to many, many factors.  All I can say is that the current Inventor team is doing all we can to revisit & address the 1,000s of functional requests that have been logged over the years of our Product's existence.  I can see how it might be easy to lose hope and I truly wish we could implement every good idea (new and old).  We are trying.
-Dan
seeyikling
Observer
Hi, I was reading the threads in hope for a solution of jogging the extension line in a linear dimension, so one of the extension line can be dragged a bit further away, so to gives nicer presentation when dimensioning it. Can anyone help me with this or where can I look for the solution/ workaround?
Come on, another basic stuff inventor keeps failing and failing over and over.
I can't consider this a CAD program if I can't place dimensions as standards recommends.
Please make this a priority.
chris_blessing
currently leadered dimensions, such as radius, don't have the ability to have a jog. It would be cool to allow for a jog /vertex point or even the ability to add another leader to point to a nearby feature.
samuel_cot
It must be done. It's not an idea, it's a standard : ASME y14.5 (1.8.2.2 Foreshortened Radii).
