I would really love to se the option to select single lines from a sketch profile, when using extrude surface. The only option is to select the whole continuous loop of connecting lines. If you could add a check box like in Boundary Patch where you can toogle on/off "Automatic edge Chain", and otherwise make the selection functionality similar to that command, it would be perfect. So that you could also select multiple single lines.
