The ability to propagate the assembly constraint dialog box with the properties of an existing constraint by selecting it in the browser, this would enable the ability to not only add constraints with the dialog as per normal but also edit existing ones as desired by selecting them in the browser after selecting apply on a previous constraint addition.<br><br>This would effectively bypass the need to get out of the assembly constraint dialog temporarily to modify or fix flare ups or flip existing constraint arrangements as you would be able to just select other constraints in the browser and their properties would appear in the constraint dialog for editing.<br><br>Cheers<br>Carl<br><br><br>
