Eliminate the "Project Geometry" Command
Why do we even need this command?  Why when creating a sketch do you have to select a command to
either pick existing geometry or a centerline or plane when needing to constrin to it?
Wouldn't it be easier to be able to just select the existing geometry, axis or plane and select the sketched entity and constrain them?
I find it a major pain when I want to constrain sketched entities to existing geometry, axis and planes to have to use this command in order to do so.
4 Comments
LT.Rusty
(A) You already can just dimension or constrain from your sketched geometry to an existing non-projected edge or point.
(B) There's other times when projected geometry comes in very useful that don't involve dimensioning or constraining.  Rails for lofts, paths for sweeps for instance.  Re-using geometry on the fly for new features.  Defining center-points for hole patterns.  I'm sure I could come up with more things I use it for.
Cadmanto
Rusty,
Let me clarify.  Yes you can do what you said.  I agree that if you want to use the "Project Geometry" command to bring existing edges into a current sketch it is useful for that.  So eliminating it I agree now may not be a good idea, but it should be at the very least tweeked.  If you need to constrain sketched geometry to a plane or axis you should be able to do it without the use of this command.  That is more where I was coming from.  Sorry clarifying that better the first go around.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
