5 Kudos
Rory_M
Editing materials in shared library
Status: Implemented
by Active Contributor Rory_M on ‎11-02-2012 05:33 AM
Please return the ability to add or edit a material or colour style and save it back to a shared material library.
Rory
Status: Implemented
In addition to the legacy solution provided for Autodesk Inventor 2013, this idea has been addressed/implemented within Autodesk Inventor 2014. Thanks!
Comments
by *Pro on ‎01-02-2013 10:22 AM
I'm no fan of the Materials and Appearances as found in 2013, but you have the ability to create or modify materials and appearances and save to a shared library.  It doesn't always work, and doesn't work nearly as neatly as the previous Styles, but the functionality is there.
by Employee dan.szymanski ‎01-28-2013 12:26 PM - edited ‎01-28-2013 12:28 PM
Status changed to: Solution Provided
Hello Rory,
As sbixler indicated below, the functionality to do what you requested does exist today. Please visit http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1364-Fundamen1364/1443-Materia... for more information. Select the "Manage materials and appearance libraries" sub topic. I would also strongly suggest that you assure you have SP1.1 & SP1.1 Update1 installed as there have been numerous fixes made within the materials & appearance domain.
Dan Szymanski
Inventor Customer Experience
by Active Contributor Rory_M on ‎02-04-2013 06:32 AM
Sorry, should have been clearer with my original post. I'm referring to the fact that when multiple users are accesing a materials library, you are "locked out" of making changes as the file is in use and read only.
Is this now fixed with the SP1.1 update or do we still have to get everyone to come out of Inventor to add materials? I can't check as I'm currently off site.
by Employee dan.szymanski on ‎04-03-2013 01:44 PM
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea.
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
