Dear development,
It is possible to run 2 inventors at the same time. I use this sometimes to run an analysis or to open big complex assemblies. This becaus if something goes wrong I can kill the process. So it would be great if each window could be a process (like chrome brouwser for example). Now if something goes wrong (a crash, or a parameter wich should've been 10 and not 10000) you only loose that file...
Another benifit would be that if you run a complex update you can continue working in another tab. So you take more advantage of you hardware.
Below a screenshot of Chrome and the taskmanager, there are 7 tabs and 7 processes.
