Dynamic Simulation Improvements
I have started using Dynamic Simulation for some of my design.  I would like to see the following improvements. Note: I am on IV 2014, so 2015 might be better.
1. Use a work axis or work plane to define the gravity direction.  The current tools either let me pick a edge or surface or define the x,y, and z components of the vector.  I need to evaluate the effects of yaw, pitch, and roll on my machines.  Allow the gravity vector to change during the simulation.
2. Allow several simulations to live in each assembly, like the FEA tool does.  I want to run several variations of loads, velocities, and accelerations in order to evaluate my design.
3. Respect Design Views, Position Reps and Levels of Detail, just like the FEA tool.  Again, I want to evaluate several design alternatives and build several different simulation models in the same source assembly.
4. Display results from several different simulations on the output grapher.
5. Assign units to the output grapher independent of the document units setting.  I might want to design a machine in inches, but need to see moments in Nm.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
