Drawing dimension alignment when model changed.
Even if the drawing dimension has been set "Center Justification", when model size changed. it becomes  very dirty.
Users have to set it again.
2 Comments
F.Goncalves
hi!
i'm having the same problem. Did you found any solution?
Thanks!
dan_szymanski
Status changed to: Archived
There are two settings available that may address this request:
Within your Drawing:
1)  Select Tools tab > Document Settings > Drawing tab, under Dimension Updates toggle options beneath "Dimension Text Alignment" to:
  • View Position
  • View Position and Maintain Centered
  • Percentage of Dimension Line
2) Select Tools tab > Application Options > Drawing tab, toggle the "Center dimension text on creation" option for desired result.
I am setting this Idea to the Archived state since the issue was resolved without need for an implementation. Thanks -Dan
