Disable Automatic PDF Viewer Display
When you use Save As > Save Copy As > PDF, or Export > PDF,  Inventor always opens the PDF viewer to show the PDF file after it is published. This can be a bother, due to the delay caused by waiting for the PDF viewer to open each time.
The current solution is to go to Export > Export to DWF and un-check the Display Published File in Viewer option found at the bottom of the General tab. This option controls the PDF viewer as well as the DWF. With this option unchecked the PDF will not open automatically after it is published.
However, this setting is not at all discoverable and also precludes the ability to set the DWF and PDF viewer open options independently. Adding an option in the PDF options dialog would resolve this. There is currently a request to add customizable default settings to the PDF export here:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Inventor-Printing-PDF-Export-ALL-PAGES/idi-p/3761...
Related links:
http://inventortrenches.blogspot.com/2012/08/disable-automatic-pdf-display.html
4 Comments
Jam_Jumpin
Mine never opens the PDF. Maybe it's a bug in my software.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
