Inventor Forum
Dimension Arc ANGLE
3 REPLIES 3
melmo
4777 Views, 3 Replies
Dimension Arc ANGLE
Sometimes I would like to dimension an arc by angle, not by length or radius/diameter.  I know that you can angle dimension the three points of the arc, but I think it would be more efficient and an improvement to the interface.  There are times when I need to dimension lots of arc angles and it quicly gets difficult to identify center points.
Tags (2)
Labels (1)
3 REPLIES 3
BryanKelley
in reply to: melmo
This can be done now after the Arc is placed within the Sketch. Start the Dimension command, select one of the endpoints, the center, then the other endpoint. It will create an angular dimension. Also, depending upon the selection order, the angle could vary. Thanks, Bryan
Bryan
Sr. Software QA Engineer
DLS – Mechanical Design
melmo
in reply to: melmo
Bryan,
Thank you for your reply; however I do not consider it a solution.  Please reread my original post, where I state that I already know that you can dimension arc angle by selecting three points.
To clarify my request, my proposal was for that option to add the ability to specify arc angle directly, e.g. via the "Dimension Type" context menu as an option in addition to "Radius", "Diameter", and "Arc Length".
As I stated above, the technique you (and I) cited is tough to implement in busy sketches, where it can be hard to loacte/identify an arc's center point.  Also, that method does not work as expected when dimensioning values greater than 180 degrees, especially when you cross from <180° to >180°, unless you constrain two of the arc's three points.
Please remove "solution provide" from the status, thank you.
BryanKelley
in reply to: melmo
Hello Melmo,
  Please see the attached images for steps.
  This is in Inventor 2015.
Thank you,
Bryan
Bryan
