• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • 27 Kudos
    Custom patterns
    Status: Accepted
    by Active Contributor streharg on ‎11-05-2012 04:59 AM
    I would like to have custom patterns!
    Patterns can stay the way they are, but besides spacing and distance, please, add custom, so users can define custom distances. That would save a lot of time! Now, have to do 2, 3 or 4 different patterns of same thing, just to get spacings right.
    Greg
    Status: Accepted
    Accepted idea [US14656]. Please continue to provide feedback on environment preference. Thanks!
    Comments
    by Valued Mentor on ‎11-05-2012 01:04 PM
    So your saying patterns based on say an embedded spread sheet with multiple different spacings?  This would be nice.
    by Valued Contributor MattH_Work on ‎11-22-2012 09:15 AM
    Add fill paterns to that list. In fact just look at the options available to NX users
    by Distinguished Contributor LT.Rusty on ‎12-03-2012 02:47 PM
    Also, make the patterns work the same way in the part and assembly environments.
    For instance:  circular pattern of 4 items @ 90 degrees in the part environment gives you 4 features spaced out over a 90 degree arc.  Go to the assembly environment, and the same thing gives you 4 features spaced 90 degrees apart.  Why the difference?
    Also, why can we do a pattern on a sketched curve in the part environment but not the assembly environment?
    by Employee smithar on ‎01-28-2013 11:06 AM
    by Valued Contributor mslosar on ‎02-21-2013 07:19 AM
    I agree as well.
    We do a number of things here that need to be arrayed around a circle. I'd say 1/2 the time the spacing isn't even.
    6 objects around a body aren't always going to be 60 degrees apart. Being able to use a table to say:
    item 2   120
    item 3   170
    item 4   240
    item 5   300
    item 6   355
    would be great!
    As it is now, the only option is is to place 6 different assemblies and their associated connection peices on the main body 6 separate times (or more depending on how many are needed).
    by Employee dan.szymanski on ‎02-27-2013 11:53 AM
    Let me pose another question. Assuming you could only receive "custom distance" functionality in one environment (Part or Assembly). Which would be more critical to all of you? This project [US14656] is under review by the development team.
    by Active Contributor streharg on ‎02-27-2013 11:25 PM
    I vote for assembly enviroment!
    Greg
    by Valued Contributor michael.marx on ‎03-07-2013 07:23 AM
    part environment is always better
    in assembly you can always link to the part pattern :-)
    by Valued Contributor MattH_Work on ‎03-12-2013 05:50 AM
    by michael.marx on ‎2013-03-07 03:23 PM
    Agreed. If we can't have both, let the Part dictate and the Assembly follow
    by Employee dan.szymanski on ‎03-18-2013 08:38 AM
    Status changed to: Accepted
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea.
