Show only
Search instead for
This idea has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it. In Inventor 2016 you can use a sketch symbol as the default balloon shape in a balloon style. In the balloon style, switch on the Used-Defined Symbol button and select a symbol from the list. NOTE: a local symbol must be present within the document in order to be referenced within the style.
I know this post is old but I cannot find a solution to this same problem. Is there a way to create custom balloon with Item & Quantity with adjustable insert-point?
If I try to create a custom balloon it looks like this.
What I want it to look like is below.
I want to create Custom Balloons like these with iProperties: Item# & QuantityDimensions of the Custom Balloons I'd like to create
