I would like to be able to calculate the principal moments (and section modulus) of an assembly.
In the part environment I can use [Cross Section Analysis] command (Inspect>Analysis>Section).
However, [Cross Section Analysis] command is not available in assembly environment.
It takes time to create one part from assemblies by using [Derive] command.
Thank you!
