Show only
Search instead for
If we couldname objects(especiallyfaces), we mightanticipatereplacingcomponant=>The software coulduse theIDto replace thereferenceconstraintswithout error.
I know iMates, but the workflow is complex for many users.
I know also, that every object has an ID readable from API.
If we had this ID displayed and editable from constraint dialog and also reachable via the context menu on componant, it would be easier to copy ID from the "old" componant to the "new" component.
jletcher,
reference constraints => it's a "copy-paste" error. It should read : The software could use the ID to modify constraints without error.
We can use the iLogic solution to replace the object for constraint. At first the object should be assigned using entity name, and the entity name can be used for iLogic rule. Does it work for you?
