19 Kudos
Countersunk-bored holes
Status: New Idea
by johnstda on ‎02-01-2014 12:22 AM
There's a fifth type of hole which is sometimes used in woodwork. It's a countersunk-bored hole. You simply use the coutersink bit to bored down into the wood after coutersinking the hole. It's used when hiding screw heads with wooden plugs. It's similar to a counter-bored hole feature except that instead of a flat bottom for the boring, it's an angled bottom, the same angle as countersinking.
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea.
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
