Content Center Structural Improvements
1/2 should be between 7/16 and 9/16 on size lists.  It should not be after 1.
This is happening in 4", 5", 12" Flat Bar
Maintain consistency with fractions or decimals if they're lengths (both rect and sq tubes have this issue)
Going through the table is extremely obtuse since it doesn't tell you what dimensions conform to what.  Most of the time I'm chosing beam based on flanges or height rather than anything.
The size selection should also be improved with more information on what all the dimensions listed actually mean.  As is, I'm using either other charts or just place a piece and play with the change size feature to find the flange/web sizes I need.
Tube and Pipes and what not where it's not by weight should also list weight per length.  Pipe/tube should also list volumetric capacity per length.  I should also be able to select material of member from this screen as sometimes I need to use stainless or aluminum or a different steel instead of the standard.  Being able to do end treatments from this screen to put them together later would also save time.
The frame generator can do a lot of this but constantly regenerates members when changes are made so I can't cut a slot or something into it and have it stay put.  (It also likes to list the parts length to a nats **** instead of just letting me round off sizes and fill in with weld.)
11 Comments
timdown73
Agreed!  Kudos!
Thinking on it, I believe another tab is warranted for end treatments since anything not as simple as "Θ° from horizontal".  What I'd really like is a "miter to beam" with a drop down for what I'm mitering to.  Probably toss a copy of the beam selector on a fifth tab as well so that everything can be done from a single menu.
Robert.Reid
AUTODESK SERIOUSLY NEEDS TO ADD THE PROPER CROSS-SECTION TO VARIOUS MATERIALS TO FRAME GENERATOR/CONTENT CENTER
STEEL I-BEAMS ARE WAY DIFFERENT THAN ALUMINUM I-BEAMS
IN FRAME GENERATOR, IF I PICK A W8 X10, AND I CHOOSE  ALUMINUM, I DO NOT GET  GET THE PROPER CROSS-SECTION THAT I AM SUPPOSE TO GET, I STILL GET A STEEL CROSS-SECTION
I THINK AUTODESK SHOULD BE LIABLE FOR THIS MAJOR SOFTWARE SCREW-UP
If the dimensions are different, then there should be a different standard selection at a higher level, presumably at the same level when you choose M, W, I, or H beam.  Same names just a (Steel) or (Aluminum) next to the designation.  Come to think of it, you should probably be able to switch between the four different types of beam without having to generate a completely new part file.
Robert.Reid
EXACTLY!
THIS IS A VERY SERIOUS ISSUE
PEOPLE ARE WASTING A LOT OF TIME USING THE WRONG SHAPES
THAT THEY THINK ARE CORRECT
ALSO THE LIABILITY OF STUFF THAT HAS BEEN ALREADY MANUFACTURED
AND OUT IN THE FIELD THAT MAY FAIL
dan_szymanski
Status changed to: Accepted
Accepted idea [12014]. Thanks!
nickada
Please review this idea Improve & Update Content Center. Please vote for this idea as it helps all of us who think the Content Center needs updating.
Thank You
dan_szymanski
Yijiang.Cai
Yijiang.Cai
@Anonymous @nickada @Robert.Reid @timdown73
we are investigating on this idea, and some progress is made. You can access the feedback community page to see what we have done
You could access the page below to understand how to join the Beta at https://forums.autodesk.com/t5/inventor-forum/inventor-feedback-beta-project-how-do-i-get-access/td-...
River
Yijiang.Cai
This has been implemented within Autodesk Inventor 2023.1. Please review the Inventor 2023.1 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
