Hi Dev team,
During the assembly, the most frequent command we use is constrain.
i would like to suggest that an option to be provided to apply the constrain automatically after selecting the required faces. (current process: we have to press "Apply").
This option should be a check box type, where users could disable it. And alsoMay be an alterable timer can be provided, incase if the designer selected the wrong faces he can cacel the constrain immediatly by pressing escape.
I strongly believe that this will help to increase the designing pace and productivity.
i am not sure, if this idea is far fetched, let you guys decided.... cheers
Thanks and Best Regards,
Pavan
