Currently the ipn environment feels somewhat out of date, so here are some points i think could be improved:
- Better design view / representation support
- Better selection options (like already posted window select idea)
- Folders for tweaks
- Folders from assembly remain
- Better / Custom trail editing
Clarification:
- Currently you can only access the representations upon creation, if you want to change this afterwards you have to start over.
- There already was an idea for window select, that would be a good improvement.
- Grouping tweaks together in a folder to represent certain area's of the explosion.
- If an assembly already contains folders they should remain and perhaps even be selectable for tweaking all contained parts at once.
- Trails are made from the tweaks, but they often have a wrong/unusual starting point on a part. Being able to choose a start point/endpoint or making a trail line out of scratch would be nice.
Kind regards,
Niels.
