I'm using the Bolted Connection command to place PEM Fasteners in my sheet metal designs and have the following two requests...
1). I'd like the function to automatically select the appropriate PEM fastener size (shank code) for the material thickness that it is being installed into.
2). I'd like the PEM fastener to update to the appropriate size (shank code) when I make a change to the sheet metal thickness.
Currently I have to do this manually which can be very time consuming.
Brian
