Better control of work features reference
There should be better control of work features reference in Inventor. For example:
*Ability to add point with offset from plane or face. I have to add a plane to do that now. This functionality would add much more power to work points. Same thing with axis, now you can add axis only directly on plane, with no ability to offset from it
*Ability to add point on line with offset from other geamotery (maybe from other point on same line or plane)
*Table-like list of references used with ability to redefine only selected reference. For example point on three planes - I have to reselect all planes when I click redefine feature, even when I want to redefine only one refenrence plane.
Now it is only thing that comes in mind, maybe I will come up with more later.
Good example of work features reference control is in Pro/Engineer.
3 Comments
andrew_buc
Regarding a point with offset from plane or face: I'd think you could put a point on the plane or face, then a grounded point at whatever distance from the first point. I realize that that's not as elegant as what you're asking for--I'm talking workaround.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
