• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    9 Kudos
    Apply constraints when reflect components (Mirror Components tool)
    Status: Accepted
    by Contributor carlos.arredondo on ‎11-16-2012 12:27 PM
    It’s very useful that you can create components mirrored applying the same contraints, because when you create a mirror in the Assambly Enviroment, the new parts (that are Derived Parts) keep all degrees of freedom. I think that is possible add a checkbox in the Mirror Components: File Names dialog box to control if you want to apply or infer the constraints or not.
    Status: Accepted
    Accepted idea [US15173]. Thanks!
    Comments
    by Distinguished Contributor JimSteinmeyer on ‎01-23-2013 03:09 PM
    This should have been a given when mirroring parts was created. The time savings for mirroring parts in an assembly is lost when I have to go back and constrain all the new parts. Grounding the parts is fine until something in the assembly changes.
    Thank you
    Jim
    by Employee dan.szymanski on ‎01-28-2013 01:36 PM
    Great idea
    by Employee dan.szymanski on ‎03-19-2013 12:21 PM
    by Employee dan.szymanski on ‎03-20-2013 12:19 PM
    Status changed to: Accepted
    by Contributor carlos.arredondo on ‎03-21-2013 07:25 AM
    Greetings dan.szymanski,
    What does this mean? It's possible that this be included in an Autodesk Inventor future release?
    Thank you so much!
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea.
