Apply constraints when reflect components (Mirror Components tool)
It’s very useful that you can create components mirrored applying the same contraints, because when you create a mirror in the Assambly Enviroment, the new parts (that are Derived Parts) keep all degrees of freedom. I think that is possible add a checkbox in the Mirror Components: File Names dialog box to control if you want to apply or infer the constraints or not.
9 Comments
This should have been a given when mirroring parts was created. The time savings for mirroring parts in an assembly is lost when I have to go back and constrain all the new parts. Grounding the parts is fine until something in the assembly changes.
Thank you
Jim
dan_szymanski
Great idea
dan_szymanski
dan_szymanski
Status changed to: Accepted
Accepted idea [US-116633]. Thanks!
Greetings dan.szymanski,
What does this mean? It's possible that this be included in an Autodesk Inventor future release?
Thank you so much!
Solidworks and ProE solved this problem years ago. I think Inventor is pretty good, and am new to it. I am really surprised this is an issue! I will look into "grounding" to see what that is.
In the meantime, Inventor Folks, please fix this ASAP!!!
steve.west
I posted a similar idea before I found this. This is a major issue for me. I had large assemblies fall apart before realiseing that mirrored parts weren't constrained. I have to manually ground each mirrored part. Very time consuming and essential to do.
ChrisMitchell01
This idea has been implemented within Autodesk Inventor 2017R2. Special thanks to everyone who cast a vote for it
jeanie.wayker
