Apply constraints when reflect components (Mirror Components tool)
It’s very useful that you can create components mirrored applying the same contraints, because when you create a mirror in the Assambly Enviroment, the new parts (that are Derived Parts) keep all degrees of freedom. I think that is possible add a checkbox in the Mirror Components: File Names dialog box to control if you want to apply or infer the constraints or not.
9 Comments
JimSteinmeyer
This should have been a given when mirroring parts was created. The time savings for mirroring parts in an assembly is lost when I have to go back and constrain all the new parts. Grounding the parts is fine until something in the assembly changes.
Thank you
Jim
dan_szymanski
Great idea
dan_szymanski
dan_szymanski
Status changed to: Accepted
Accepted idea [US-116633]. Thanks!
Greetings dan.szymanski,
What does this mean? It's possible that this be included in an Autodesk Inventor future release?
Thank you so much!
neil.hamilton
Solidworks and ProE solved this problem years ago. I think Inventor is pretty good, and am new to it. I am really surprised this is an issue! I will look into "grounding" to see what that is.
In the meantime, Inventor Folks, please fix this ASAP!!!
steve.west
I posted a similar idea before I found this. This is a major issue for me. I had large assemblies fall apart before realiseing that mirrored parts weren't constrained. I have to manually ground each mirrored part. Very time consuming and essential to do.
ChrisMitchell01
This idea has been implemented within Autodesk Inventor 2017R2. Special thanks to everyone who cast a vote for it
jeanie.wayker
