Show only
Search instead for
Add separate visibility switch to Drawing view menu.
Please add a separate visibility switch as shown below. Sometimes I need it on and sometime I need it off; if I need it off I have to go into the text menu and clear out the second property (A click fest that gets old by the second time). Thanks!
They had that option back when Inventor worked. They had to take it out to make room for the new interface..
But yes it should have never been taken out I used it often and when they took it out I was upset because now you have extra clicks to remove it. But they seem to like adding clicks and wasting time...
Yeah, I mean, I MS painted that button in the image and it was funny because there's still a spot for it to fit perfectly. I have no idea why they would remove that button, it makes no sense. Let's hope they add it back in.
