Want to have the ability to add a mass override to each member in an iPart. There are lots of iParts that are just meant to be a representation but you still want the mass to be correct.
It would be nice if you could just assign a custom column to be the "Mass" the same way you can for filename / colour.
To achieve this now I have an addin that makes a new material for each member and adjusts the density based on the volume and selected mass.
