As far as I know, the only property I can actually define for each individual sheet (for use in iLogic, text fields, Title Block, etc.) is the sheet name. This is extremely limiting. Each sheet in my drawings has several properties of its own: sheet's drawing number, what component(s) are detailed on the sheet, the designer, etc. I would love to be able to use each of these properties in labels on the sheet; for example, in a text box with "<Sheet Drawing #> - <Component(s)> (<Designer>)". The only possible way I could do something like this is to use the sheet's drawing number as the Sheet Name, and then use that value in the sheet's text labels, headings, and title block. However, I want to be able to use descriptive names for the Sheet Name, plus that's just one property.
There should be some way to define multiple custom properties for individual sheets, and these properties should be available for use in iLogic and within text notations.
(see related Discussion Groups post: http://forums.autodesk.com/t5/Autodesk-Inventor/Custom-sheet-properties-not-drawing/td-p/3887110)
