Problem:
Multiple radius dimension arrow lines not merged properly with dimension lines. When dimension moves, It does not get impacted and it stays alone.
Root cause:
Creator manually matches arrow lines with dimension lines for multiple radius dimensions.
Loss:
Impacts quality of the drawing
Consumes drawing creation time
Proposed option:
Add Vertex/Leader can be added in radius dimension arrow lines.
It is available for chamfer dimension arrow same used for example
