Ability to insert user parameters directly in rule editor
It would be very useful and time saving to have an option to insert user parameters directly in rule editor. And after inserting parameter it is directly inserted in Parameters.
Example (see images): right click -> insert user parameter (numeric, text, ...)  -> Add Numeric  -> your parameter - OK
Adam
4 Comments
jtylerbc
Access to the Export setting and Custom Property Format of the parameters from this location would be handy as well.  This would allow you to set up all of your parameters as needed for iLogic rules relating to iProperties, without having to switch back and forth between the iLogic rule editor and the Parameters dialog box.
It would be much easier for the users if we could create new parameters through the iLogic rule creation window.
As it is currently, users need to close the rule window and open the parameters window, create the parameter and then open the rule window again.
It would be easier if the parameters could be created without going through all of that opening and closing of windows.
If you agree, please "Kudos" this idea.
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-3605].
