• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    32 Kudos
    brendan.henderson
    ADD "USE SAME MEMBER" SELECTOR TO FRAME GENERATOR
    Status: Under Review
    by Distinguished Contributor brendan.henderson on ‎12-19-2012 04:41 PM
    When adding members to a frame, instead of having to select the family and size and such have a selector to pick an existing member in the frame and make consume that selection to the Standard, Family, Size and Material Style. Could save a lot of time having to get frame member info BEFORE adding members to the frame.
    Fair enough Brendan. Changing status from duplicate to Under Review.
    Comments
    by *Expert Elite* on ‎01-09-2013 11:09 AM
    This is a little known feature.... may not even be intentional,... but:
    If you preselect a piece of steel in your FG assembly and THEN select "Insert Frame" from the ribbon, the dialog will open with the properties of the item you have pre-selected.  It's very handy!
    btw... this also works in Tube & Pipe.  Select a fitting on the screen and select the Place Fitting button.... bam!  There it is ready for placement without having to navigate the CC.
    by Distinguished Contributor BLHDrafting on ‎01-10-2013 12:19 PM
    Great tip. Might even use that in my blog 1 day. Still think a button would be good. Many thanks!
    by Employee smithar on ‎01-25-2013 09:45 AM
    Status changed to: Solution Provided
    by Employee bryan.kelley on ‎01-28-2013 02:27 PM
    This project [US5180] is under review by the development team.
    by Employee dan.szymanski on ‎02-06-2013 12:03 PM
    Status changed to: Duplicate
    This is the same request / idea as cited under Frame Generator Member Reuse - located here: http://forums.autodesk.com/t5/Inventor-IdeaStation/Frame-Generator-Member-Reuse/idi-p/3687532 Setting this idea as duplicate as the other idea has more kudos. -Dan
    by Distinguished Contributor brendan.henderson on ‎02-07-2013 04:27 PM
    I'm not so sure that this should be made a duplicate. My suggestion was for a button in the FG window that when clicked would allow me to pick an existing frame member and populate the FG member selection windows with the chosen members info (Standard, Family, Size, Material, Appearance and Orientation). The other topic is talking about re-using the placed member in the frame, like making a pattern of the member. Regards, Brendan Henderson CAD Manager/Product Development Manager 'Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning' [KEOGH_EMBLEM_505_BY_132_TRANSPARENT_BG] _________________________________________________________________________________ From: B. Keogh & Sons Manufacturing Pty Ltd Phone: +61 3 5446 8377 Facsimile: +61 3 5446 1178 Mobile: +61 0428 509 212 E-mail: brendan.henderson@augers.com.au ********************************************************************************************************************* The Information contained in this E-Mail is confidential and intended solely for the use of the addressee(s) If you receive this E-Mail in error, any use, distribution or copying of this E-Mail is NOT permitted Please notify or forward unwanted E-Mail to the contact details above. B. Keogh & Sons Manufacturing Pty Ltd does not represent that this communication, or any future communication, is: (a) free of viruses or other defects, nor (b) received by you in the original form in which it was sent and without having been intercepted and/or tampered with by third parties, and specifically disclaims liability to you and any other person for any loss or damage resulting (directly or indirectly) from the receipt or use of this communication (including any attachments). *********************************************************************************************************************
    by Employee dan.szymanski on ‎02-08-2013 07:01 AM
    by *Expert Elite* on ‎03-14-2013 12:23 PM
    This can sort of be done now.  Before selecting the button to place a new frame member, select and highlight a member on your frame that is the same as the one you want placed.  Now when you select Insert Frame, the dialog will be populated with the frame profile information of that piece you selected.  All you have to set is the orientation, and place it.  Saves a ton of time.
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea.
