Dear Sirs,
I'm trying to show an extruded work surface in an idw view, but it won't allow what can be done with a normal work plane will do.
Is there a way to do this?
See attached ipt file showing the pitch diameter work surface that I want to show up in an idw view.
Thanks ... Chris
Solved by mflayler2. Go to Solution.
Right click on the part in the Drawing Browser (you might have to drill down into the view) and select the Include All Surfaces option.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Thanks Mark!
I figured it was something simple.
Cheers ... Chris
