Inventor Forum
wmf files from Inventor 7
11 REPLIES 11
Message 1 of 12
ykcad
658 Views, 11 Replies
How can I get a wmf file from a Inventor 7 drawing to insert in a Word document?
Yngve Karlsson
Sweden
11 REPLIES 11
Message 2 of 12
in reply to: ykcad
Not easily...But there is a way :-
Save as DWG from Inventor
Open the DWG file in AutoCAD
Use the WMFOUT command in AutoCAD
Hope this is of use to you
Rory
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
How
Yngve Karlsson
Sweden
Message 3 of 12
in reply to: ykcad
Actually I think there is still a program on Charles site called Export Preview Images
that I started and Charles finished that does it. Unfortunately they are just the preview
image stored in the file though.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Rory" wrote in message
news:C985B28CDFEA8B3F7F1E0C6A3A861E41@in.WebX.maYIadrTaRb...
> Rory
> "ynka" wrote in message news:f1a1d37.-1@WebX.maYIadrTaRb...
> Yngve Karlsson
> Sweden
Message 4 of 12
in reply to: ykcad
"Kent Keller" wrote in message
news:2F70D63DD381907887AD45C5C0D612CD@in.WebX.maYIadrTaRb...
Preview Images
just the preview
Won't that be a raster image though rather than a vector based one?
Maybe R9 will let us copy & paste into Word.... 😉
Rory
Message 5 of 12
in reply to: ykcad
The export is a WMF, that as I remember scales properly. This isn't the addin program,
but rather a standalone EXE.
The other thing you could use that scales well is DWF. Just use insert special and you
can embed the DWF in Word.
Kent
Assistant Moderator
> Rory
Message 6 of 12
in reply to: ykcad
But if you do that (DWF), doesn't anyone accessing the Word doc also need to
have AutoCAD Express Viewer installed? WMF's don't require additional
software.
Bob
"Kent Keller" wrote in message news:619FC7E85F843C4C3DCC8C941FC333C7@in.WebX.maYIadrTaRb...
> Kent
> Assistant Moderator
Message 7 of 12
rllthomas
in reply to: ykcad
DXF works in word. It has to be setup in the install options though....
CGM is another vector format that is popular in word.
It is also very easy for people to copy a portion of a PDF and paste it into a word file although it is raster data at that point. In Acrobat, the text select button is actually a flyout. You can toggle to graphics select, window a region and copy paste.
If you really need vector I would suggest you research HPGL/2, CGM, WMF, and DXF. Word will support many of those if all the converters (filters) are installed.
Rich Thomas
Message 8 of 12
in reply to: ykcad
I am not sure about that. I would suspect that also, but I seem to remember trying it
with some other "insert special" (maybe volo??) and it worked if I am remembering right.
Kent
Assistant Moderator
"Bob" wrote in message
news:33BF237D1C314D4F8D60A9E045D97FF0@in.WebX.maYIadrTaRb...
> software.
> Bob
Message 9 of 12
in reply to: ykcad
I have used HPGL in the past. There is a filter in Word. I think you
need to be careful in setting up the Print Driver for Windows so you get
the old form (not PCL) output when plotting to an HPGL file from Inventor.
> Rich Thomas
Message 10 of 12
in reply to: ykcad
If you have full blown Acrobat, you can also save a
PDF page as Encapsulated Postscript
and if the PDF file was created using Inventor
drawing plots, the postscript will be vector format.
I have done that in the past also for
catalogs
Bob
Rich Thomas
Message 11 of 12
in reply to: ykcad
Charles is correct about HPGL, you must select a Printer/Plotter that writes
a PLT file in the HPGL language.
(HPGL/2 will not work)
I have the filter at the office used in MS Office that will allow placing
PLT files into Word. You would use
Insert - Picture - From file then browse to your PLT file(s).
If you are using Word 98 or ealier this Filter is alreayd in Word. However
from Word 2000 on Microsoft for some reason removed it. I can post or E-mail
the filter file to anyone that wants it. I will also try and post the
location of the file at the Microsoft WEB site once I find it again. That
way more of you can get the Filter quicker by downloading it yourself.
Message 12 of 12
in reply to: ykcad
Correction, pre Word 97 had the filter. But here is the Microsoft WEB
address for the file.
Be sure to read the directions for installation.
http://support.microsoft.com/default.aspx?scid=kb;en-us;196506
