Which version of windows are you using 32bit or 64 bit? As far as i know you cannot read the thumbnails in the 64bit version, you need to find and use the 32bit Explorer that is in your system, i can't remember where it's at, but it's there. It's one of the problems of using IV2008 on a 64bit system.
msk
I have this problem too. All the inventor files (part assy & drw) doesnt show thumbnail preview in the windows explorer.
any solution ?
C1
IV2012 Professional
Windows 7, 64 bit
I assume you are asking aif I use 64 bit OS. Yes I use Windows 7 64 Bit.
Also I am sure we can see thumb nail preview in windows 7 64 bit. Its because I have witnessed it on my friends windows 7 64 bit computer.
Did you try to start and close Design Assistant to give Inventor the chance to fully register all the hooks that we use into Windows Explorer?
Bob
Use following command to start a 32 explorer on a 64 bit machine:
%systemroot%\SysWOW64\explorer.exe /separate
See also TS13795910
Hopefully that will give you thumbnail capability.
Bob
