Inventor General
Distinguished Contributor
kmeldfreyssinet
Message 1 of 9 (285 Views)
why top in inventor is not compatible with other Autodesk software
285 Views, 8 Replies
12-17-2012 12:34 AM
HI,
till now it was not o big problem for me but now it got very anoying.
In Inven tor top wiev is on ZX plane, so along Y axis. In all other programs (Autocad, 3DS, Schowcase, Design review) top is on XY so along Z. Also it is comon everywhere that Z axis is taken as vertical.
Why Inventor sode not foolo this common aproach?
One may say that it is not really important because it is all relative. But not quite.
There are many problems related with this non concistensy when you try to import model from Inventor to 3DS (or other) and use some basic tools for daylite generation.
Either you have to rotate whalle model or castomize lighting environment.
Can I somehow change setings of inventor so that Z axis would be taken as vertical, and TOP wiev would schow XY.
Could this be fixed?
Cris
Member
Patrick.Korpel
Message 2 of 9 (269 Views)
Re: why top in inventor is not compatible with other Autodesk software
12-17-2012 01:28 AM in reply to: kmeldfreyssinet
Hi Cris,
You can change the view orientation by clicking on the Contect Menu next to the viewcube (see pic-1).
Then select via the pull-down menu Set Current View As -> Top (see pic-2).
I haven't found a setting where you can change it as standard.
I hope this helps.
You can also change the standard first sketch plane while creating a new part.
Tools/Aplication options/ sketch tab (see third attachment)
Regards
kmeldfreyssinet
Message 3 of 9 (266 Views)
12-17-2012 01:38 AM in reply to: kmeldfreyssinet
this may work.
for the first look it did what I want, but I will further investigate this behaviour.
Cris
Member
Patrick.Korpel
Message 4 of 9 (256 Views)
12-17-2012 01:47 AM in reply to: kmeldfreyssinet
I've found an option for it in the viewcube options (also in the context menu).
There you can change the standard TOP and FRONT view plane (see attachment).
I haven't tried it myselve, but I assume this is a permanent solution, the previous one you have to execute in every assembly.
Regards
*Expert Elite*
Message 5 of 9 (225 Views)
12-17-2012 04:44 AM in reply to: kmeldfreyssinet
Cris
AutoCAD was originally a 2D program.
Inventor, SolidWorks and Creo (Pro/E) use the same convention.
As noted you can right click on the View Cube to reset how you need.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Contributor
Message 6 of 9 (207 Views)
12-17-2012 05:17 AM in reply to: kmeldfreyssinet
Which version of 3ds Max are you using?  As I recall, there is an option in the import dialog box for Inventor files to specifically account for this (at least in 3ds Max 2012).
-Using Autodesk Inventor Professional 2012
kmeldfreyssinet
Message 7 of 9 (188 Views)
12-17-2012 06:06 AM in reply to: kmeldfreyssinet
I am starting with 2012 version, but right now I am completely new to 3DS.
I noticed some terrible spelling in my original post ;-). Please forgive me.
Cris.
*Expert Elite*
Curtis_Waguespack
Message 8 of 9 (160 Views)
12-17-2012 07:24 AM in reply to: kmeldfreyssinet
Hi  kmeldfreyssinet,
Here's a link that might help with Showcase:
http://forums.autodesk.com/t5/Autodesk-Inventor/Showcase-and-inventor/m-p/3403249#M430800
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Distinguished Mentor
Message 9 of 9 (148 Views)
12-17-2012 07:49 AM in reply to: kmeldfreyssinet
We have our templates with the XY plane set to top here.
John Retzlaff
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
