Inventor Forum
why I rant
28 REPLIES 28
Message 1 of 29
jletcher
1163 Views, 28 Replies
why I rant
Here is a prime example of the reason I rant about new interface...
I know this has nothing to do with the new interface but does it. all the time they screwed with the new interface they could have been fixing this kind of stuff.
You want a new interface get inventor to work with less bugs oh I know you can't get rid of all the bugs or can you?
To move forward without fixing the issues you have.
So if I offend any of the users in the fourms I am sorry but when I am working hard and need to do something and Inventor does not and then a new Interface comes into play but yet the bug that was in the old release is never fixed this is why they want you on subscription so maybe some day in the next 200 releases this bug in 2011 may get fixed.
OK I'm done.....
Any one know what pic is here?
28 REPLIES 28
Message 21 of 29
cwhetten
in reply to: jletcher
There are thousands of samples right here in this forum.  People have posted many examples of code for all kinds of purposes.
Message 22 of 29
jletcher
in reply to: cwhetten
Yes, you are correct this is how I learned what I know plus a small course I found. But I am moving into the advance of ilogic and those samples and codes are few.
I have to give Curtis Waguespack the biggest kudos there is. If it was not for him I would be stuck dreaming of the things I wish to do.
Again Curtis I can not thank you enough for your help. Smiley Happy
Message 23 of 29
cwhetten
As Jonathan mentioned above, iLogic is based on VB.net.  If you really want to dig into the meat of iLogic, (and become as knowledgeable as Curtis), then I think you want to learn VB.  There is a lot more info out there about VB than iLogic.
I have been meaning to learn VB myself, but I just haven't gotten around to it yet.  I guess I'm not sure where to start, but since I have had success learning some programming at university, I would probably do well to just shell out some cash and take a course on VB.
Message 24 of 29
jletcher
Yes and No I can write VB like the back of my hand but I for some reason cannot convert VB to ilogic but I have not given up this weekend I spent hours trying things and learned somethings.. and if you read the beginning of this post my problem is when I go to the API help I get a whole lot of cannot display this is why I can't learn the things I want to.
Autodesk is more focus on useless Interfaces and taking the best help I have ever seen and turn into the biggest crappiest help I have ever seen in a software in years.
Like I said I no longer promote Inventor.
I had one guy remember how I raved about Inventor and he was telling someone about it and said hang on hey Jim come tell Steve about Inventor. I said what Inventor Never herd of it.....................
Message 25 of 29
mrattray
iLogic is a lot closer to VBA then VB. Look at internet help for VBA and use the API's object browser, not VB help.
Mike (not Matt) Rattray
Message 26 of 29
"Your buddy John said it would not work for what I need. I understand I logic but what I can't find are the things that make ilogic go. The code and samples..."
I feel that I need to clarify my answer to you.
Our course teaches the user the ins and outs of iLogic.  We show them the process and give them the tools "to make iLogic go".  We DO offer examples and include part files with our course to help the user understand.
You're looking for a large library of code to copy and paste from.  That is not what we sell.  This is why I said that our course probably isn't what you're looking for.
Message 27 of 29
jletcher
No I understand what you said but then the other guy said it is what i need unless i read his wrong it is monday..
I looked into the course, for new ilogic users i would suggest it to them.
But as you said not for me Smiley Sad
Message 28 of 29
jdkriek
99% of the time I use the VBA without much modification in iLogic - aside from assigning a reference to an object and a few shortcuts that iLogic has provided, they will function the same. Some of my scripts might be a tad shorter if I use the iLogic shortcut version of something, but there's certainly no diffrence when it gets executed. I've done VERY advanced scripts from VBA to iLogic and it took a grand total of 2 minutes to convert it.
Let me give you an example:
VBA:
Public Sub RemoveFeature()
	Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
	Dim oFeature As PartFeature
	Dim oFeatures As PartFeatures
    Set oFeatures = oDoc.ComponentDefinition.Features
        For Each oFeature In oFeatures
            If oFeature.Name = "NameOfYourFeature" Then
                oFeature.Delete
        Next
End Sub
But I can run almost the exact same code in iLogic.
Notice I'm not using Set and in many cases you don't even need to Dim anything.
It's still assigning a reference to an object.
iLogic:
			oFeature.Delete
    Next
Revised iLogic:
Now, that will work just fine, but if we dig a little deeper we'll find that we can simplify the code in iLogic thanks to it's VB.NET additions Try/Catch along with other shortcuts as mentioned before.
oDoc = ThisDoc.Document
Try
oFeatures("NameOfYourFeature").Delete
Catch
MsgBox("No feature exists with that name")
End Try
Does that help?
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 29 of 29
jletcher
in reply to: jdkriek
Lets add to this. Here is a bug and this is what I wish Autodesk would fix not add more features with bugs but fix the ones they have than move forward....
Win some lose some Smiley Happy
No reply needed no I will not post offending part I know it will work in 2013 lol.
Slow down on the upgrades fix issues than come out with a banging 2014 make me proud to say I use Inventor....
Smiley Happy
