Inventor Forum
whats going on with shrinkwrap?
4 REPLIES 4
stephengibson76
441 Views, 4 Replies
I need to find the displacement of a hollow part so thought shrinkwrap would be a good idea but it doesnt work as i expected, this is my workflow
create a cube 10mm^3
shell it 2mm wall thk
add to an assembly and shrinkwrap, solids leave the shell there which i want to remove, (simplification, remove geometry by visability, parts and faces is greyed out with solids), so i create it as a single composite feature, (removes the shell)
Check volume of new part and its still the shelled volume, so i sculpt the part to turn back into a solid.
check volume of new part again a 10mm^3 part has a volume of 1784mm^3????????
What am i doing wrong?
Stephen Gibson
View stephen gibson's profile on LinkedIn
4 REPLIES 4
ok so it gives me the actual volume plus the volume from the original part... 1000+784. how do I remove this associativity with the original part
Stephen Gibson
ok i have answered my own question, click the break link option when shrinkwrapping the assembly and all works fine
Stephen Gibson
Would an alternative to breaking the link be per below:
1. Start new file- Assembly.
2. Place parent assembly of shrink-wrapped file.
3. Place shrink-wrapped file, co-incident with parent.
4. Save.
5. Start new Part file.
6. Place derived instance of your recently created assy.
7. Set the Original assy instance to Subtractive.
This is my signature, not part of my post.
This is as designed so that although the assembly has a substitute/shrinkwrap it still maintains all of the materials & mechanical properties of the original assembly. If it didn't do this in most cases it would make using this feature very awkward.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
