Inventor General
Valued Contributor
bms953
Message 1 of 25 (422 Views)
what is this error???? and why happend ?
422 Views, 24 Replies
10-26-2012 02:02 PM
i create a part and use that as Drive part in some another part, when i want do anything like select Feature , create Sketch , adding Constraint , .... this error appear for me  (((( a Cyclical constraint dependency was detected ))))
i attached file
Behzad Meskini
freedom for Iran
*Expert Elite*
karthur1
Message 2 of 25 (392 Views)
Re: what is this error???? and why happend ?
10-26-2012 07:40 PM in reply to: bms953
Can you post the Door Panel.ipt?
Valued Contributor
bms953
Message 3 of 25 (379 Views)
10-27-2012 12:26 AM in reply to: karthur1
tnx for respond
Behzad Meskini
freedom for Iran
Valued Contributor
bms953
Message 4 of 25 (354 Views)
10-27-2012 10:43 AM in reply to: bms953
any solution
Behzad Meskini
freedom for Iran
Valued Contributor
hosford
Message 5 of 25 (338 Views)
10-27-2012 12:04 PM in reply to: bms953
I didnt get the error you show.
Why are you using a sweep?
M6700, i7-3820QM, 32GB, 512 SSD
Win 7 Ultimate 64
Nvidia K3000M
Inventor 2015
Valued Contributor
bms953
Message 6 of 25 (335 Views)
10-27-2012 12:14 PM in reply to: hosford
sweep for create an edge around door , door has many part and every part is around main structure of door has this sweep
Behzad Meskini
freedom for Iran
Valued Contributor
bms953
Message 7 of 25 (335 Views)
10-27-2012 12:15 PM in reply to: hosford
do u can create a door Panel with Multi body from Drive part with out any error?
Behzad Meskini
freedom for Iran
Valued Contributor
hosford
Message 8 of 25 (328 Views)
10-27-2012 12:29 PM in reply to: bms953
Couldnt you just extrude the required lip?
Win 7 Ultimate 64
Nvidia K3000M
Inventor 2015
Valued Contributor
bms953
Message 9 of 25 (325 Views)
10-27-2012 12:36 PM in reply to: hosford
yes i can, but for extrude i should create some another rectangle in sketch , as well as my problem isn't Sweep or Extrude , problem is this error A Cyclical Constraint dependency was detected.
Behzad Meskini
freedom for Iran
Valued Contributor
hosford
Message 10 of 25 (321 Views)
10-27-2012 01:01 PM in reply to: bms953
ok, I have downloaded your models, played around in them, added extrusions, sketches, and cant get the error you have.
Do you get this error when trying to make a new sketch?
Win 7 Ultimate 64
Nvidia K3000M
Inventor 2015
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
