Inventor Forum
what is this error???? and why happend ?
24 REPLIES 24
Message 1 of 25
bms953
1801 Views, 24 Replies
i create a part and use that as Drive part in some another part, when i want do anything like select Feature , create Sketch , adding Constraint , .... this error appear for me  (((( a Cyclical constraint dependency was detected ))))
i attached file
Behzad Meskini
Competitor in World skills Competition 2005 Finland (Mech,Eng,CADD)
Member of Iranian Elite Foundation
Autodesk Certified Professional-AutoCAD
Autodesk Certified Professional-Inventor Pro
Autodesk Certified Professional-3ds Max
Autodesk Certified Professional-Revit Architecture
Autodesk Certified Professional-Revit Structure
Autodesk Certified Professional-Revit MEP
DS CATIA Certified V5 Mechanical Surface Designer Specialist
DS CATIA Certified V5 Associate - Part Design
DS CATIA Certified V5 Associate - Surface Design
DS Solidworks-CSWP-Mechanical Design Professional
DS Solidworks-CSWA-Advanced Sheet Metal Professional
DS Solidworks-CSWA-Advanced Weldments Professional
DS Solidworks-CSWA-Advanced Surface Professional
DS Solidworks-CSWA-Advanced Drawing Professional
24 REPLIES 24
Message 21 of 25
bms953
in reply to: JDMather
after i See JDMather and karthur1 post,  i try to download SP1.1 and install that , redraw sketch in new part and put every panel in separate Block ( JDMather advise ) but when i want insert coincident betwen 2 point of Block again ........ look to pic
Behzad Meskini
Message 22 of 25
bms953
in reply to: bms953
my system configuration is :
CPU Core i7 3610 QM
VGA ; GForce GTX 660m
Ram : 8GB
HDD : 750 GB
WIN 7 Home Pre
Office 2003
i Update my Windows and Inventor SP
i want know has this error relationship with this config????
Behzad Meskini
Message 23 of 25
bms953
in reply to: karthur1
interesting , i download a sample file from this forum and try to change for find solution and again this **** error appear.
should i reinstall Inventor ??!!!???!!  Man Sad
Behzad Meskini
Message 24 of 25
karthur1
in reply to: bms953
Probably first try the repair install.  If that doesnt work you could do the reinstall.  Did you install SP1.1?
Message 25 of 25
bms953
in reply to: bms953
ok, tnx , yes i Install SP1.1
Behzad Meskini
