Inventor General
Valued Contributor
Message 21 of 25 (149 Views)
Re: what is this error???? and why happend ?
10-28-2012 12:27 PM in reply to: JDMather
after i See JDMather and karthur1 post,  i try to download SP1.1 and install that , redraw sketch in new part and put every panel in separate Block ( JDMather advise ) but when i want insert coincident betwen 2 point of Block again ........ look to pic
Behzad Meskini
freedom for Iran
Valued Contributor
Message 22 of 25 (147 Views)
10-28-2012 01:00 PM in reply to: bms953
my system configuration is :
CPU Core i7 3610 QM
VGA ; GForce GTX 660m
Ram : 8GB
HDD : 750 GB
WIN 7 Home Pre
Office 2003
i Update my Windows and Inventor SP
i want know has this error relationship with this config????
Behzad Meskini
freedom for Iran
Valued Contributor
Message 23 of 25 (141 Views)
10-28-2012 02:40 PM in reply to: karthur1
interesting , i download a sample file from this forum and try to change for find solution and again this **** error appear.
should i reinstall Inventor ??!!!???!!  :mansad:
Behzad Meskini
freedom for Iran
*Expert Elite*
karthur1
Message 24 of 25 (104 Views)
10-29-2012 08:47 AM in reply to: bms953
Probably first try the repair install.  If that doesnt work you could do the reinstall.  Did you install SP1.1?
Valued Contributor
Message 25 of 25 (87 Views)
10-29-2012 09:48 AM in reply to: bms953
ok, tnx , yes i Install SP1.1
Behzad Meskini
freedom for Iran
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
