i create a part and use that as Drive part in some another part, when i want do anything like select Feature , create Sketch , adding Constraint , .... this error appear for me (((( a Cyclical constraint dependency was detected ))))
i attached file
tnx for respond
any solution
I didnt get the error you show.
Why are you using a sweep?
sweep for create an edge around door , door has many part and every part is around main structure of door has this sweep
do u can create a door Panel with Multi body from Drive part with out any error?
Couldnt you just extrude the required lip?
yes i can, but for extrude i should create some another rectangle in sketch , as well as my problem isn't Sweep or Extrude , problem is this error A Cyclical Constraint dependency was detected.
ok, I have downloaded your models, played around in them, added extrusions, sketches, and cant get the error you have.
Do you get this error when trying to make a new sketch?
any work, like this pic i attached , i want create an Extrude Cut and i have this error
I dont know what to tell you.
have you rebooted since the problem accured?
see attached image.
thank you very much for help to me, yes i have rebooted file and i still have this problem
JDMather , karthur1 , DarrenP or any other Master on this forum, Help
I'm like the others that posted. I don't see an error when I try to extrude cut either. Can you zoom out just a little so we can see what you are picking when you extrude?
I also tried to create a new door panel (new body) and did not get an error.
Are you using the latest SP1.1 update. Not sure if it makes any difference.
i reopen my file and when i want right click in design tree and delete some feature i have this error , i try to create this file again for 3 time but all of them have this problem, i just Install Inventor 2013 and i have not install SP 1.1
i download ur file and try to do something and i have not any error
If I were doing this model I think I would do as multi-body solids in a single part file and then push out the individual parts.
There appears to be total symmetry on my quick inspection that almost all the sketches (in the master file) can be simplified by half.
Notice that these areas do not automatically highlight for Extrude and the Sketch Doctor - Red Cross appears in the Extrude dialog box.
I recomend simplyfing the sketch.
In my experience I will do parts of it on one side of the centerline and other parts on the other side trying to avoid overlap and no reason to duplicate work.
There seems (to me) to be an excessive number of geometry constraints in this sketch.
Running Sketch Doctor ( several times) I was partially able to fix the sketch, but not entirely.
I recommend starting over and no dulplication.
