Inventor Forum
what i did wrong ?
3 REPLIES 3
281 Views, 3 Replies
what i did wrong ?
i could not extrude this four line CLOSED profile. it keep saying the profile is not closed. when i drew the fourth line, i moved the cursor to the first line starting end as close as i can and also watch the end trun yellowish. adding dimensions did not help.
thanks.
3 REPLIES 3
admaiora
Your profile is not closed.(No coincident constraint at the ends)
You may have your coincident inference not selected.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
blair
It may have looked closed, but you didn't have any constraints on the line end points, possibly you have turned off the constraints setting for sketches. You can drag the lines independent of each other. Open the sketch and run the Sketch Doctor to constrain the line end points.
Delta Tau Chi ΔΤΧ
in reply to: admaiora
i do not have the icon you circled in the ribbon. your INV version?
thanks.
ps. i got it fixed in constrains option window.
