style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
"davejan" <davejan@snet.net>Just
wrote in message
href="news:f129109.0@WebX.maYIadrTaRb">news:f129109.0@WebX.maYIadrTaRb...
wondering, is K:\manufacured files listed as, or underneath a directory listed
as a project library path?? If I remember correctly, IV 6 will not let you
modify files in library direcories.. That sounds like the same error I got
when I tried to do it.
David
"jiml" <jiml@cadd.com> wrote inif
message
href="news:f129109.1@WebX.maYIadrTaRb">news:f129109.1@WebX.maYIadrTaRb...
this is a custom title block idw open the templet 1st save templet back as
save copy as over write the old then open idw see what
happens
"jiml" <jiml@cadd.com> wrote inso
message
href="news:f129109.4@WebX.maYIadrTaRb">news:f129109.4@WebX.maYIadrTaRb...
in this idw you don't have your name of the company or any thing it is a stock
idw templet nothin added
"davejan" <davejan@snet.net>Do
wrote in message
href="news:f129109.6@WebX.maYIadrTaRb">news:f129109.6@WebX.maYIadrTaRb...
you have problems with any other idw's in this directory?
try copying the idw (and probably the ipt/iam) to a directory not listed in
your library and try to open it (you'll probably have to redirect the link to
the source ipt/idw) alternately, you could just remove the directory from the
library search path and try to open the idw, see if that helps. I had a
problem similar (I only had one sheet) to this and removing it from the
library search fixed it.
David
"davejan" <davejan@snet.net>search
wrote in message
href="news:f129109.7@WebX.maYIadrTaRb">news:f129109.7@WebX.maYIadrTaRb...
the board for "library search" and a message thread called "yet another
problem" where library search files were discussed.
David
"Josh Beissel" <
href="mailto:josh@felling.com">josh@felling.com> wrote in message
href="news:3ED8338D647EE81DE32FFB070BD46CAC@in.WebX.maYIadrTaRb">news:3ED8338D647EE81DE32FFB070BD......
I'm really not sure what I should do
here.....
"davejan" <search
href="mailto:davejan@snet.net">davejan@snet.net> wrote in message
David
"davejan" <davejan@snet.net>Have
wrote in message
href="news:f129109.11@WebX.maYIadrTaRb">news:f129109.11@WebX.maYIadrTaRb...
you tried changing the library search paths or setting a new default project
that doesn't include the directory in its library search? This will fix it if
that is the problem. If the library path isn't your problem, then its possibly
a migration issue.. and I can't help you there.
There are a few threads under the "library search" search topic. A few of
them might give you hints as to how your projects files should be structured.
apparently Its screwed up a lot of people so far.
David
